A problem with 3d visualization on MATLAB
Luckybuilding
Member level 1
Member level 1
banaie.persiangig.com
I wanna create a 3d surface for my data representing an object.
I have obtained the data for borders of each slice.
However, I can't create any surface!
Used code is:
for a=1:length(D(1,1,:))
    X=D(:,:,a);
    BW = im2bw(X,mp,0.75);
    CC = bwconncomp(BW);
    for b=1:CC.NumObjects
        clear TMP;
        TMP=cell2mat(CC.PixelIdxList(b));
        if isempty(find(TMP==fix(p_f)))
            BW(CC.PixelIdxList{b}) = 0;
        end
    end
    O(:,:,a)=imfill(BW,'holes');
end
figure;
phandles = contourslice(O,[],[],[20:57],1);
view(3); axis tight
set(phandles,'LineWidth',2)
Os = smooth3(O);
hiso = patch(isosurface(Os,1),...
    'FaceColor',[1,.75,.65],...
    'EdgeColor','none');
The output image is shown below:
How can I create the surface out of these borders?
Thanks
I believe you need a more sophisticated rendering engine. It will connect neighboring data points to create a surface.
It will have features such as shading, hidden surface hiding, etc.
Thanks for your reply.
However, can you be specific and suggest an engine for this?
If MATLAB has a 3D rendering module available somewhere, then you're all set.
Otherwise you'll need to use a different programming package.
List of various 3D software rendering engines:
Also look into modules such as OpenGL, TBGL, and DirectX. These go with certain programming languages.
Or for a simple surface drawing method...
Draw vertical lines between a data point on one level, to a related data point on another level. Do this several times and it won't be too hard to visualize a solid object.
