Borisw37
- Joined
- Dec 16, 2013
- Messages
- 6
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1
- Activity points
- 65
I'm trying to come up with a simple function to do basically frequency division / multiplication. This will be written in C running on a PIC32, but doesn't really effect the basic math.
Inputs to the function are:
- Integer variable "Frame" that increments on an constant time base.
- Integer "Speed" in 1/16 increment (Rate * 16 for integer math).
What I want the function to return is "increment". Think of this as an animation.
A few examples of what I want the function to do:
Speed = 16 (16/16 = 1, thus function should increment on every Frame)
Frame = 0, 1, 2, 3, 4, 5, ....
Result = 1, 1, 1, 1, 1, 1, ....
Speed = 32 (32/16 = 2, thus function should increment twice on every Frame)
Result = 2, 2, 2, 2, 2, 2, ....
Speed = 8 (8/16 = 1/2, thus function should increment on every 2nd Frame)
Result = 0, 1, 0, 1, 0, 1, ....
Speed = 20 (20/16 = 5/4, thus function should increment on every Frame, twice on every 4th frame)
Frame = 0, 1, 2, 3, 4, 5, 6, 7, 8, 9 ....
Result = 1, 1, 1, 2, 1, 1, 1, 2, 1, 1 ....
Speed = 12 (12/16 = 3/4, thus function should increment on every Frame, except for every 4th)
Frame = 0, 1, 2, 3, 4, 5, 6, ....
Result = 0, 1, 1, 1, 0, 1, 1, ....
I hope I'm making sense. I think this should be possible using the modulo operator but having a brain fart coming up with a function.
If ((Frame*16)%(Speed*16) == 0) ?
Thank you,
Boris.
Thank you,
Boris.
