abhijitdutta2005
Newbie
- Joined
- Apr 6, 2013
- Messages
- 4
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Activity points
- 1,322
My circuit works at 5V LS TTL level. The power supply is derived from 2200V AC, 50Hz ->12V down to 5V using 7805 regulator and 470uF+ 0.1uF filter capacitors. The supply has less than 100mV noise.Any time there is a low to high transition in my logic circuit, always there's a glitch of 1mS. The high to low is always clean. The glitch actually reaches 5V. I see a clear triangle of width 1mS.
If I put an RC to damp the rise time, the next stage of logic this re-appears. Can anyone help? Attached a simple picture. I tried putting a re-triggerable 555 monoshot. but it does not help. Any time there's a low to high transition, this glitch appears. It's not oscilloscope issue, as I put this through a shift register (LS164) there is see clearly a shift of 2. I put this pulse to a D-FF (LS74) with D input ties high and strangely the Q output going low to high also shows this, whereas, the first edge of glitch having brought Q to high should not have changed the output when the second rising edge of clock comes...
