May 14, 2018 #1 S sky_above Member level 2 Joined May 14, 2018 Messages 43 Helped 0 Reputation 0 Reaction score 0 Trophy points 6 Activity points 375 4 bit multiplier from 2 bit multiplier Can you make a multiplier which can multiply 4 bit inputs with the help of multipliers which can multiply 2 bit inputs and other logic ? Please provide the schematic.
May 14, 2018 #2 J jbeniston Advanced Member level 1 Joined May 5, 2005 Messages 460 Helped 106 Reputation 214 Reaction score 73 Trophy points 1,308 Activity points 3,494 Re: 4 bit multiplier from 2 bit multiplier I can. No.
May 14, 2018 #3 KlausST Advanced Member level 7 Joined Apr 17, 2014 Messages 25,158 Helped 4,868 Reputation 9,757 Reaction score 5,536 Trophy points 1,393 Activity points 168,346 Re: 4 bit multiplier from 2 bit multiplier Hi, First please confirm * that all input values have to be seen as unsigned integers. * that your 2 x 2 multiplier has full 4 bits of utput value. ******* My hint: do a decimal multiplication step by step (each digit) by hand. like "12 x 23" Then do the same step by step with the binary multiplication. If you don´t get the correct result, then show us how you did the calculation. Klaus
May 14, 2018 #4 FvM Super Moderator Staff member Joined Jan 22, 2008 Messages 52,400 Helped 14,748 Reputation 29,778 Reaction score 14,093 Trophy points 1,393 Location Bochum, Germany Activity points 298,003 Re: 4 bit multiplier from 2 bit multiplier Think of the multiply problem (a+b)*(c+d). You get 4 partial products, then sum it.
