9v, 3 Amps psu, limit @ 2.7 Amps new attempt
jonnybgood
Full Member level 4
hi,
my friend sent me this circuit for my 9v power supply. He told me that he used to build it when he was younger and it gave him very good regulation. I am not sure on the current limiting PNP transistor i should use, its collector resistor, the 2 base resistors...
My friend, you dont need this mess on circuit, you can just use LM350 (3A) or LM338T (5A TO220) - LM338K (5A TO3) with nice heatsink and all ok.
IC voltage regulators have builted in protection for overcurrent and overheating.
You can set 9V if you need, current also can be limited. You can also set others voltage if you need.
As above tpetar wrote...............
For 9Vdc / 3A power supply ( Imax. = 5A )
You need 12Vac transformer ( 60...75VA or bigger )
10A / 100Vmin. bridge or diodes
Filter capacitors
trimmer pot. and few resistors
and a LM338K in TO-3 case assembled in large enough finned heat sink
Look page 8. : 1.2V–25V Adjustable Regulator
or in page 7. : Regulator with Protection Diodes
https://www.ti.com/lit/ds/symlink/lm338.pdf
You're talking about a -10% error in current limit, which could
easily be from component tolerances, board design, etc. Or
input source sagging. An excellent opportunity to hone your
bench debug skills.
