Mithun_K_Das
Advanced Member level 3
- Joined
- Apr 24, 2010
- Messages
- 899
- Helped
- 24
- Reputation
- 48
- Reaction score
- 26
- Trophy points
- 1,318
- Location
- Dhaka, Bangladesh, Bangladesh
- Activity points
- 8,254
Need an example code for 8X8 Dot Matrix LED display in microC.
Basically I was trying to make one. I tried in many ways but it doesn't work. I don't know what was wrong I was doing....
here is my file:
Also found some example but that is not working too...
and proteus files:
here is my file:
Code C - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 const unsigned short letters[16] = { 0x18,0x3C,0x66,0x66,0x7E,0x7E,0x66,0x66, //A 0xFF, 0x00, 0x76, 0x76, 0x76, 0x89, 0xFF, 0xFF //B }; unsigned short column, num, repeat, count; void main() // Programme principal { TRISD = 0x00;//all output TRISC = 0x00;//all output while(1) // Boucle infinie { for (num=0;num<2;num++) { for (repeat=0; repeat<20; repeat++) { column = 1; for (count = num*8;count < (num*8+8);count++) { PORTD = letters[count]; PORTC = column; column = column<<1; delay_ms(1); } } Delay_ms(1000); } } }
Code C - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 /* ********************************************************** Exercice d'affichage multiplexé sur une matrice de 8x8 LEDs. PIC16F876A - Anodes communes sur le portB et Cathodes sur PortC ***********************************************************/ int i,j; // variable de comptage int v,lettre; // variable de fréquence de scrolling //unsigned short IncCol; // Variable d'incrémentation de colonne unsigned short offset; void main() // Programme principal { // Préparation du caractère affichable // Tableau de huits entiers (8x8) */ const unsigned char colonnes[][8]={ {0xEB, 0x81, 0x98, 0x3D, 0xBC, 0x19, 0x81, 0xD7}, {0xC3, 0xC3, 0x3C, 0x24, 0x24, 0x3C, 0xC3, 0xC3}, {0xff, 0x81, 0xbd, 0xa5, 0xa5, 0xbd, 0x81, 0xff}, {0xEB, 0x81, 0x98, 0x3D, 0xBC, 0x19, 0x81, 0xD7}, {0xAA, 0x55, 0xAA, 0x55, 0xAA, 0x55, 0xAA, 0x55}, {0x42, 0xC3, 0x3C, 0x24, 0x24, 0x3C, 0xC3, 0x42}, {0xC3, 0xC3, 0x3C, 0x24, 0x24, 0x3C, 0xC3, 0xC3}, {0xC3, 0xC3, 0x3C, 0x3C, 0x3C, 0x3C, 0xC3, 0xC3}, {0xC3, 0xC3, 0x00, 0x18, 0x18, 0x00, 0xC3, 0xC3}, {0xC3, 0xC3, 0x00, 0x00, 0x00, 0x00, 0xC3, 0xC3}, {0x24, 0x24, 0xE7, 0x00, 0x00, 0xE7, 0x24, 0x24}, {0x18, 0x24, 0x42, 0x99, 0x99, 0x42, 0x24, 0x18}, {0x00, 0x62, 0x62, 0x7E, 0x62, 0x62, 0x62, 0x00}, {0x00, 0x7E, 0x60, 0x78, 0x60, 0x60, 0x7E, 0x00}, {0x00, 0x3C, 0x62, 0x7E, 0x62, 0x62, 0x62, 0x00}, {0x00, 0x7C, 0x62, 0x7C, 0x62, 0x62, 0x62, 0x00}, {0x00, 0x7E, 0x18, 0x18, 0x18, 0x18, 0x3C, 0x00}, {0x00, 0x42, 0x24, 0x18, 0x18, 0x18, 0x3C, 0x00}, {0x18, 0x0C, 0x06, 0xFF, 0xFF, 0x06, 0x0C, 0x18}, }; ADCON0=0; // ADC désactivé TRISA=0; // PORTA configuré en sortie TRISB=0; // PORTB configuré en sortie TRISC=0; // PORTC configuré en sortie PORTA=0; // mise à zéro des ports A PORTB=0; // mise à zéro des ports B PORTC=0; // mise à zéro des ports C lettre=0; v=0; j=0; offset=0; PortC = 0; while(1) // Boucle infinie { for (i=0;i<8;i++) // itération sur les 8 lignes { PortB = (colonnes[lettre][i])<<offset; // output valeur colonnes de la ligne courante PortC = 1<<i; // sélection ligne courante Delay_ms(1); } } }
and proteus files:
