Code C - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 void display_numeric_test() { unsigned char data_display[4]; if (UCSRA & 0x80) { data_display[0]=data_display[1]; data_display[1]=data_display[2]; data_display[2]=data_display[3]; data_display[3]=UDR; } display_character_pattern(data_display[0],data_display[1],data_display[2],data_display[3]); display_clear(); }
Friend, what's UDR and UCSRA ?
serial_char=Serial_read();
serial_send(serial_char);
switch(serial_char)
case 'a':
//clear_screen();
display_spectrum();
break;
case 'r':
display_numeric();
break;
No problem, thanksoh, i'm sorry, that's for AVR. ok, i will change it.
Code C - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 void display_numeric_test() { unsigned char data_display[4]; if (RI) { RI=0; data_display[0]=data_display[1]; data_display[1]=data_display[2]; data_display[2]=data_display[3]; data_display[3]=SBUF; } display_character_pattern(data_display[0],data_display[1],data_display[2],data_display[3]); }
display_character_pattern(33,15,21,30)
first condition, data_display[0]=X, data_display[1]=X, data_display[2]=X, data_display[3]=X.
after receive data 33 from PC => data_display[0]=X, data_display[1]=X, data_display[2]=X, data_display[3]=33.
after receive data 15 from PC => data_display[0]=X, data_display[1]=X, data_display[2]=33, data_display[3]=15.
after receive data 21 from PC => data_display[0]=X, data_display[1]=33, data_display[2]=15, data_display[3]=21.
after receive data 30 from PC => data_display[0]=33, data_display[1]=15, data_display[2]=21, data_display[3]=30.
case 2:
try
MatrixLED->Open();
this->label1->Text = "Connected";
MatrixLED->WriteLine("r");
x = MatrixLED->ReadLine();
this->label1->Text = x;
MatrixLED->Close();
//this->label1->Text = "Disconnected";
Like this ?first condition, data_display[0]=X, data_display[1]=X, data_display[2]=X, data_display[3]=X.
void display_numeric_test(){
if (RI)
RI=0;
else if (RI)
RI=0;
data_display[2]=SBUF;
data_display[3]=data_display[4];
unsigned char Serial_read() {
SCON = 0x50; /* SCON: mode 1, 8-bit UART, enable rcvr */
TMOD |= 0x20; /* TMOD: timer 1, mode 2, 8-bit reload */
TH1 = 253; /* TH1: reload value for 9600 baud @ 11.0592MHz +/- 3.5% error */
TL1 = 253;
TR1 = 1; /* TR1: timer 1 run */
TI = 1; /* TI: set TI to send first char of UART */
display_wait();
printf("\n Enter `a` to continue \n");
while(!RI);
RI = 0;
return SBUF;
//display_numeric_test();
switch(serial_char)
case 'a':
//clear_screen();
display_character_pattern(10,10,10,15);
break;
case 'b':
display_character_pattern(10,10,10,16);
break;
Code C - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 unsigned char data_display[4]; void ser_int () interrupt 4 { if (RI) { RI=0; data_display[0]=data_display[1]; data_display[1]=data_display[2]; data_display[2]=data_display[3]; data_display[3]=SBUF; } }; void main () { SCON = 0x50; TMOD = 0x20; TH1 = 253; TR1 = 1; RI = 0; TI = 0; ES = 1; EA = 1; while (1) { display_character_pattern(data_display[0],data_display[1],data_display[2],data_display[3]); }; };
I think we miss something,we can use delay after each character is sent, or use interrupt to quick handle incoming data.
[Syntax=C]
SCON = 0x52; /* SCON: mode 1, 8-bit UART, enable rcvr */
TL1 = 253;
display_wait();
while(!RI);
RI = 0;
return SBUF;
unsigned char data_display[4];void display_numeric_test() interrupt 4
//unsigned char data_display[4];
if (RI)
RI=0;
main()
Serial_read();
[/syntax]
