Li_ereunpisan
Full Member level 5
- Joined
- Jul 14, 2009
- Messages
- 260
- Helped
- 32
- Reputation
- 64
- Reaction score
- 28
- Trophy points
- 1,308
- Location
- Bandung, Indonesia
- Activity points
- 2,768
I will be designing using MT8870 DTMF detector and using the HT9200 DTMF Generator both use AT89C51 .....
I have made it alone detector and generator run ,, the results ok .... I want to combine both, but the code that I made did not work .. please help me in troubleshooting the code just use asm
;---------------A U T O D I A L E R-------------------
;-----------------------Bismillah----------------------
;bit ouput------------------------
led bit p2.7
htcs BIT P2.4
htclk BIT P2.6
htdin BIT P2.5
rly_hook_urt BIT P2.1;active high
rly_hook_wtr BIT P3.5;active low
tone bit p2.3
;bit input----------------------
in_hook bit p2.0
std bit p3.2
rev_pol bit p3.6
ring_wtr bit p3.7
counter equ 22h
flagtone equ 21h
Org 0H ;Reset Vector
Ajmp init ;
Org 3H ;External Interrupt 0 Vector
Reti ;
Org 0BH ;Timer 0 Interrupt Vector
Reti ;
Org 13H ;External Interrupt 1 Vector
Reti ;
Org 1BH ;Timer 1 Interrupt Vector
ljmp tone425 ;
Org 23H ;Serial Interrupt Vector
Reti ;
init:
acall delay50
clr htcs
clr tr1
clr ea
res_inc_pstn:
clr 20h
lcall blank_memory ;reset memory
setb rly_hook_wtr ;witura on_hook
clr rly_hook_urt ;eurotech on_hook
;------------standby status-----------------
led_kiceup: ; setb ring_wtr
clr led
jb ring_wtr,c_r_h ;tlp asup ti witura???
acall delay200ms
setb led
acall delay200ms
clr led
acall delay200ms
setb led
acall delay200ms
uwih: SJMP led_kiceup
c_r_h: setb ring_wtr
jb ring_wtr,$ ;call progress 1
acall delay200ms
jb ring_wtr,$
acall delay200ms
jb ring_wtr,$ ;call progress 2
acall delay50
clr rly_hook_wtr ;witura auto answer /off hook
jb in_hook,$
tone_act: setb flagtone
mov tmod,#12h
setb ea
setb et1
setb tr1
;--------------------detect loop sadayana tujuan--------------------------
det_dial:
mov r0,#30h
loopb:
mov p1,#0fh
call delay_1
setb rev_pol
jnb rev_pol,start1
setb std
jnb std,loopb
clr led
clr c
dtmf_valid:
jnb flagtone,det_dial1
clr tr1
clr ea
clr flagtone
det_dial1:
clr led ;led dial indication
clr c
mov a,p1
MOV @R0,A
INC R0
setb LED
clr p3.0
;-------------ngantosan dial sampei 2 detik------------
MOV 23H,#0aH ;antosan dipencet
MOV R6,#00H
MOV R7,#00H
antosan_dipencet: setb rev_pol
jnb rev_pol,start1
setb std
jb std,loopb
DJNZ R7,antosan_dipencet
DJNZ R6,antosan_dipencet
DJNZ 23H,antosan_dipencet
DIALING: ;--------nulis dtmf------------
MOV R0,#30H
setb rly_hook_urt ;eurotech off hook
;acall delay50
;acall delay50
;acall delay50
setb rev_pol
jnb rev_pol,start1
acall delay200ms
AMBIL_DATA: setb rev_pol
jnb rev_pol,start1
CLR C
MOV A,@R0
MOV 25H,A
acall convert ;/dial 200ms tos fixed
setb rev_pol
jnb rev_pol,start1
INC R0
MOV A,25H
mov p0,a
CJNE A,#0FFH,AMBIL_DATA
;-------------------------mangga geura ngawaos--------------
CALLING: setb rev_pol
jnb rev_pol,start1;walaikumsalam`
clr led
acall delay50
setb led
acall delay50
sjmp calling
start1:ajmp init
CONVERT:;ngarobah dtmf
dig1:
CLR C
MOV A,25H
CJNE A,#01H,dig2
;push acc
acall dig_1
;pop acc
ret
dig2:
CLR C
MOV A,25H
CJNE A,#02H,dig3
;push acc
acall dig_2
;pop acc
ret
dig3:
CLR C
MOV A,25H
CJNE A,#03H,dig4
;push acc
acall dig_3
;pop acc
ret
dig4:
CLR C
MOV A,25H
CJNE A,#04H,dig5
;push acc
acall dig_4
;pop acc
ret
dig5:
CLR C
MOV A,25H
CJNE A,#05H,dig6
;push acc
acall dig_5
;pop acc
ret
dig6:
CLR C
MOV A,25H
CJNE A,#06H,dig7
;push acc
acall dig_6
;pop acc
ret
dig7:
CLR C
MOV A,25H
CJNE A,#07H,dig8
push acc
acall dig_7
pop acc
ret
dig8:
CLR C
MOV A,25H
CJNE A,#08H,dig9
;push acc
acall dig_8
;pop acc
ret
dig9:
CLR C
MOV A,25H
CJNE A,#09H,dig0
;push acc
acall dig_9
;pop acc
ret
dig0:
CLR C
MOV A,25H
CJNE A,#0aH,CONV_END
;push acc
acall dig_0
;pop acc
CONV_END:
RET
;-----------------------dial 9200----------------------------
dig_1:
mov a,#1h
mov counter,#5
send1:
acall send_dtmf
djnz counter,send1
acall stop_dtmf
ret
dig_2:
mov a,#2h
mov counter,#5
send2:
acall send_dtmf
djnz counter,send2
acall stop_dtmf
ret
dig_3:
mov a,#3h
mov counter,#5
send3:
acall send_dtmf
djnz counter,send3
acall stop_dtmf
ret
dig_4:
mov a,#4h
mov counter,#5
send4:
acall send_dtmf
djnz counter,send4
acall stop_dtmf
ret
dig_5:
mov a,#5h
mov counter,#5
send5:
acall send_dtmf
djnz counter,send5
acall stop_dtmf
ret
dig_6:
mov a,#6h
mov counter,#5
send6:
acall send_dtmf
djnz counter,send6
acall stop_dtmf
ret
dig_7:
mov a,#7h
mov counter,#5
send7:
acall send_dtmf
djnz counter,send7
acall stop_dtmf
ret
dig_8:
mov a,#8h
mov counter,#5
send8:
acall send_dtmf
djnz counter,send8
acall stop_dtmf
ret
dig_9:
mov a,#9h
mov counter,#5
send9:
acall send_dtmf
djnz counter,send9
acall stop_dtmf
ret
dig_0:
mov a,#0ah
mov counter,#5
send0:
acall send_dtmf
djnz counter,send0
acall stop_dtmf
ret
send_dtmf:
setb htclk
acall delay50
rrc a
mov htdin,c
clr htclk
acall delay50
ret
stop_dtmf:
mov a,#0ffh
mov counter,#5
muter5x:
acall send_dtmf
djnz counter,muter5x
acall delay200ms
ret
Delay50: push 06h
push 07h
MOV R6,#150
Del50:
MOV R7,#165
DJNZ R7,$
DJNZ R6,Del50
pop 07h
pop 06h
RET
DELAY_1: push 07h
MOV R7,#00H
TUNGG: DJNZ R7,TUNGG
pop 07h
RET
delay200ms: acall delay50
acall delay50
acall delay50
acall delay50
ret
blank_memory:
MOV R0,#30H ;Genaral purpose ram
MOV R1,#20H
ISI_LAGI: MOV @R0,#0FFH
INC R0
DJNZ R1,ISI_LAGI
ret
; GENERATOR 425 HZ
tone425:
MOV TH1,#-5H
MOV TL1,#0D0H
cpl tone
CLR TF1
RETI
;----------------Shodakallohilaziim-----------
END
