Jun 28, 2008 #1 A aho1363 Newbie level 4 Joined Dec 1, 2005 Messages 6 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Activity points 1,425 Hi to All I try to find a 80MS/S 10-bit 8-channel A/D. I couldn't find any one by search in TI,National,AnalogDevice,...:idea: Could you help me pls.? Thanx.
Jun 28, 2008 #2 S sunjimmy Full Member level 2 Joined Jan 10, 2003 Messages 128 Helped 9 Reputation 18 Reaction score 7 Trophy points 1,298 Activity points 1,027 Dear My friend, I don't think that you can find the part with 8-channel 10-bit 80MSPS ADC. If possible, you should use 8pcs ADC to fulfill your requirement. May you kindly let us know what kind of application you plan to build ?? Thanks,
Jun 28, 2008 #3 B Bus Master Full Member level 3 Joined Dec 9, 2001 Messages 186 Helped 9 Reputation 18 Reaction score 3 Trophy points 1,298 Location Just behind You ;-) Activity points 1,455 have you checked with Maxim website? www.maxim-ic.com They have a very wide range of choices.
Jun 29, 2008 #4 A aho1363 Newbie level 4 Joined Dec 1, 2005 Messages 6 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Activity points 1,425 Bus Master said: have you checked with Maxim website? www.maxim-ic.com They have a very wide range of choices. Click to expand... I have cheched Maxiam it has only MAX1438/7/6 that it is 8-channel LVDS 1.8v 12bit 65/50/40 ADC, Such as TI. Added after 5 minutes: sunjimmy said: Dear My friend, I don't think that you can find the part with 8-channel 10-bit 80MSPS ADC. If possible, you should use 8pcs ADC to fulfill your requirement. May you kindly let us know what kind of application you plan to build ?? Thanks, Click to expand... I need it for wide band Digital Receiver it has 6-channel and systematically simulation tells us each one must sampled synchronously at least with 81MS/s.
Jun 29, 2008 #5 FvM Super Moderator Staff member Joined Jan 22, 2008 Messages 52,513 Helped 14,758 Reputation 29,798 Reaction score 14,128 Trophy points 1,393 Location Bochum, Germany Activity points 298,483 You are right, major vendors don't have it. You have to use dual channel LTC2289 or similar.
