some 8086 programs
Hello,
Setup two pointers using 8 bit registers.
Initialize the first one to the last address of your list
Initialize the second pointer to the address following the last of your original list
Copy the content of the address pointed by first pointer to the address pointed by the second
Decrement first pointer and decrement second pointer.
Loop copy/increment/decrement steps 127 times.
If you understood what I have write, and you need the data in the original area, you must be able to modify the given algorithm to do it.
Homework to compensate what you have not do: Repeat exercise using just one memory address, and not a 128 byte area, as in the solution given.
Regards!
