glk.c.93
Newbie level 1
Iam using ESA51E board, having 80C51BH Ucontroller forn intel.
In my code iam trying to Implement real time clock using timer
When i check for register values in Win51E they wont get updated, while other values does...(like PC, DPTR...etc). im also using 8255
The change of values takes place in ISR, which is not happening. Interrpt is nt getting activated.. what might the problem be?
My code is:
My code is:
Code ASM - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 ORG 8100H MOV TCON, #00H MOV TMOD,#01H ; setting the timer mode to 01 MOV DPTR,#0E803H ; setting control port to have port A & B as output and port C as input , we take what to display as input MOV A,#85H MOVX @DPTR,A MOV DPTR,#9000H ; initialising time and date MOV A,#50 ; sec MOVX @DPTR,A INC DPTR MOV A,#00 ; min MOVX @DPTR,A INC DPTR MOV A,#04 ; hour MOVX @DPTR,A INC DPTR MOV A,#26 MOVX @DPTR,A INC DPTR MOV A,#08 MOVX @DPTR,A INC DPTR MOV A,#13 MOVX @DPTR,A SEC_DELAY: MOV R0,#167 ; one second delay routine REPEAT: CLR TF0 MOV TL0,#60H MOV TH0,#0EAH SETB TR0 TIMER_LOOP: JNB TF0,DISPLAY ; repeat SEC_DELAY if timer flag is set CLR TF0 CLR TR0 DJNZ R0,REPEAT ACALL UPDATE SJMP SEC_DELAY UPDATE: MOV DPTR,#9000H ; update second MOVX A,@DPTR INC A CJNE A,#60,SAVE_TIME MOV A,#00H MOVX @DPTR,A INC DPTR ; update minute MOVX A,@DPTR INC A CJNE A,#60,SAVE_TIME MOV A,#00H MOVX @DPTR,A INC DPTR ; update hour MOVX A,@DPTR INC A CJNE A,#24,SAVE_TIME MOV A,#00H MOVX @DPTR,A INC DPTR ; update date MOVX A,@DPTR ; read Date INC A MOV R2, A INC DPTR MOVX A, @DPTR ; reading month MOV DPTR, #84FFH MOVC A, @A+DPTR ; reading valid days in a month INC A MOV DPTR, #9003H MOV 3, 2 MOV 2, A MOV A, 3 CJNE A, 2, SAVE_TIME MOV A,#01H MOVX @DPTR,A INC DPTR ; update month MOVX A,@DPTR INC A CJNE A,#13,SAVE_TIME MOV A,#01H MOVX @DPTR,A INC DPTR ; update year MOVX A,@DPTR INC A MOVX @DPTR,A RET SAVE_TIME: MOVX @DPTR,A ; routine to save time and date parameters in the external memory RET DISPLAY: MOV DPTR,#0E802H ; complete display routine MOVX A,@DPTR JB ACC.3,DATE_DISP ; pin 3 of port C used as mode pin, high=>display date, low=>display time TIME_UPDATE: MOV DPTR,#9000H ; second MOVX A,@DPTR MOV B, #0AH DIV AB ; dividing to get units and tens digits of second MOV R1,A ACALL NUMBER_DISPLAY ; call the routine to display a number MOV A,#00111110B ; units place 7-segment display is on, rest are off MOV DPTR,#0E801H MOVX @DPTR,A ACALL SMALL_DELAY ; small delay MOV A,#0FFH ; to turn off all 7-segment displays MOVX @DPTR,A MOV B,R1 ACALL NUMBER_DISPLAY MOV A,#00111101B ; tens place 7-segment display and so on further MOV DPTR,#0E801H MOVX @DPTR,A ACALL SMALL_DELAY MOV A,#0FFH MOVX @DPTR,A MOV DPTR,#9001H ; minutes MOVX A,@DPTR MOV B, #0AH DIV AB MOV R1,A ACALL NUMBER_DISPLAY MOV A,#00111011B MOV DPTR,#0E801H MOVX @DPTR,A ACALL SMALL_DELAY MOV A,#0FFH MOVX @DPTR,A MOV B,R1 ACALL NUMBER_DISPLAY MOV A,#00110111B MOV DPTR,#0E801H MOVX @DPTR,A ACALL SMALL_DELAY MOV A,#0FFH MOVX @DPTR,A MOV DPTR,#9002H ; hours MOVX A,@DPTR MOV B, #0AH DIV AB MOV R1,A ACALL NUMBER_DISPLAY MOV A,#00101111B MOV DPTR,#0E801H MOVX @DPTR,A ACALL SMALL_DELAY MOV A,#0FFH MOVX @DPTR,A MOV B,R1 ACALL NUMBER_DISPLAY MOV A,#00011111B MOV DPTR,#0E801H MOVX @DPTR,A ACALL SMALL_DELAY MOV A,#0FFH MOVX @DPTR,A LJMP TIMER_LOOP DATE_DISP: MOV DPTR,#9005H ; year MOVX A,@DPTR MOV B, #0AH DIV AB MOV R1,A ACALL NUMBER_DISPLAY MOV A,#00111110B MOV DPTR,#0E801H MOVX @DPTR,A ACALL SMALL_DELAY MOV A,#0FFH MOVX @DPTR,A MOV B,R1 ACALL NUMBER_DISPLAY MOV A,#00111101B MOV DPTR,#0E801H MOVX @DPTR,A ACALL SMALL_DELAY MOV A,#0FFH MOVX @DPTR,A MOV DPTR,#9004H ; month MOVX A,@DPTR MOV B, #0AH DIV AB MOV R1,A ACALL NUMBER_DISPLAY MOV A,#00111011B MOV DPTR,#0E801H MOVX @DPTR,A ACALL SMALL_DELAY MOV A,#0FFH MOVX @DPTR,A MOV B,R1 ACALL NUMBER_DISPLAY MOV A,#00110111B MOV DPTR,#0E801H MOVX @DPTR,A ACALL SMALL_DELAY MOV A,#0FFH MOVX @DPTR,A MOV DPTR,#9003H ; date MOVX A,@DPTR MOV B, #0AH DIV AB MOV R1,A ACALL NUMBER_DISPLAY MOV A,#00101111B MOV DPTR,#0E801H MOVX @DPTR,A ACALL SMALL_DELAY MOV A,#0FFH MOVX @DPTR,A MOV B,R1 ACALL NUMBER_DISPLAY MOV A,#00011111B MOV DPTR,#0E801H MOVX @DPTR,A ACALL SMALL_DELAY MOV A,#0FFH MOVX @DPTR,A LJMP TIMER_LOOP NUMBER_DISPLAY: MOV A,#00H ; display zero CJNE A,B,L1 MOV DPTR,#0E800H MOV A,#3FH MOVX @DPTR,A SJMP EXIT_NUMBER_DISPLAY L1: MOV A,#01H ; display one CJNE A,B,L2 MOV DPTR,#0E800H MOV A,#00000110B MOVX @DPTR,A SJMP EXIT_NUMBER_DISPLAY L2: MOV A,#02H ; display two CJNE A,B,L3 MOV DPTR,#0E800H MOV A,#5BH MOVX @DPTR,A SJMP EXIT_NUMBER_DISPLAY L3: MOV A,#03H ; display three CJNE A,B,L4 MOV DPTR,#0E800H MOV A,#4FH MOVX @DPTR,A SJMP EXIT_NUMBER_DISPLAY L4: MOV A,#04H ; display four CJNE A,B,L5 MOV DPTR,#0E800H MOV A,#66H MOVX @DPTR,A SJMP EXIT_NUMBER_DISPLAY L5: MOV A,#05H ; display five CJNE A,B,L6 MOV DPTR,#0E800H MOV A,#6DH MOVX @DPTR,A SJMP EXIT_NUMBER_DISPLAY L6: MOV A,#06H ; display six CJNE A,B,L7 MOV DPTR,#0E800H MOV A,#7DH MOVX @DPTR,A SJMP EXIT_NUMBER_DISPLAY L7: MOV A,#07H ; display seven CJNE A,B,L8 MOV DPTR,#0E800H MOV A,#07H MOVX @DPTR,A SJMP EXIT_NUMBER_DISPLAY L8: MOV A,#08H ; display eight CJNE A,B,L9 MOV DPTR,#0E800H MOV A,#7FH MOVX @DPTR,A SJMP EXIT_NUMBER_DISPLAY L9: MOV DPTR,#0E800H ; display nine MOV A,#6FH MOVX @DPTR,A EXIT_NUMBER_DISPLAY: RET SMALL_DELAY : MOV R3,#10 DELAY_AGAIN: DJNZ R3,DELAY_AGAIN RET END
