[SOLVED] 8051 hex value sending to a single port
thannara123
India
Hi how can i send a hex data to a single port as serially
for example
i need to send the following data to
P0_1 = oxff;
how can i do this simply
please help me
Re: 8051 hex value sending to a single pot
Hello thannara? Serial means? just like shift register or SPI or UART or I2C?
i want to give the data to a serial shift register
Sending 0xff serially means to set the port to constantly "1". :)
If 0xff is just an example for an arbitrary value, you should use a shift instruction in your favourite programming language and run it in a loop eight times, sending the carry bit to the port (or the lowest/highest bit before the shift, whatever you prefer). To make the data stream readable to anyone, you would want to apply a specific time delay for each bit (asynchronous serial transmission) or send a clock along with the data (synchronous serial transmission).
but sir tats just example if 0x10; how can i ?
please see the following example.
array[] = {0x23,0x10,0xff,0x34,0x00,0x12};
for(i=0;i<5; i++)
P1_0 = array;
Please take a look at the above C code:
void SendSerial (unsigned char data)
  unsigned char bMask;
  for (bMask = 0x80; bMask; bMask >>= 1)
    if (data & bMask)
      pin = 1;
    else
      pin = 0;
    //You could add a delay here if you wish
If you need the byte to be sent with the reverse order, just implement the loop from 1 to 0x80 and rotating left.
Hope that helped.
thanx aleex pleas explain using comment
what is the "data"
or
how can i interface 8051 with 74Hc595
in c programm
thannara123 said:
pleas explain using comment what is the "data"
Variable "data" is the hex value that is going to be serially shifted. So using your own example:
for(i = 0; i < 5; i++)
  SendSerial(array[i]);
Inside SendSerial() function replace variable "pin" with P1_0, and you have your example working.
About 74HC595:
https://www.edaboard.com/threads/213613/
