Doesn't like a reasonably designed and matched LDPA. -10 dB (magnitude 0.3) or better -20 dB should be feasible, particularly for the intended small frequency range. Even a regular yagi antenna should perform better over the 0.8 to 1.2 GHz range.
I can achieve a good response to specific frequencies with the LPDA but I need a similar response between 800-1200MHz.
I adjust the elements to zoom in these "notch responses" but fails because when the response of a element is close to each other there are phase problems.
I need to know if is possible achieve a good and similar response with this antenna made in a PCB.
