cameo_2007
Advanced Member level 3
- Joined
- Mar 15, 2007
- Messages
- 748
- Helped
- 70
- Reputation
- 142
- Reaction score
- 44
- Trophy points
- 1,308
- Location
- 12°58' N77°38'E
- Activity points
- 5,023
Note: This feature currently requires accessing the site using the built-in Safari browser.
if the PCB is as per standards then the pad 1st pin would be in square shape and the rest pads will be circle....
if you could look inside the casing which encloses the pin Usually there will be number written next to the pins... if it is present in the connector you are using.
