Oct 10, 2011 #1 G gravity123 Newbie level 6 Joined Mar 30, 2011 Messages 12 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Activity points 1,363 I didn't get how can use 74HC595 shift register .Need to serial to parallel connection and its working . SHCP ,STCP & and DS How can i save data in IC ? (in which pins goes HIGH ie SHCP or STCP ). How can i shift the saved data ?
Oct 10, 2011 #2 J john blue Advanced Member level 3 Joined Jun 7, 2007 Messages 821 Helped 213 Reputation 430 Reaction score 204 Trophy points 1,323 Activity points 4,749 Interfacing PIC18F4550 with 74HC595 - YouTube
Oct 10, 2011 #3 alexan_e Administrator Joined Mar 16, 2008 Messages 11,888 Helped 2,021 Reputation 4,158 Reaction score 2,031 Trophy points 1,393 Location Greece Activity points 64,371 See https://www.edaboard.com/threads/227254/#post969041 Alex
Oct 10, 2011 #4 J john blue Advanced Member level 3 Joined Jun 7, 2007 Messages 821 Helped 213 Reputation 430 Reaction score 204 Trophy points 1,323 Activity points 4,749 DS line will be your data input line thats where you send your data into 595. Toggle SHCP will shift the data into the 595. If you toggle 8 times, then, 8 bit of your data will be loaded to it. STCP will shift the data out when toggled
