74164 need help with led ?
Full Member level 4
egypt
hii,
i make aled matrix display but did i must use diver ( transistor ) with 74164 ?
can i direct connect 74164 with led by (100 ohm resistor) .
erikl
Super Moderator
Staff member
Germany
Depends on the 74164 type: LS types should be loaded by 8mA only, other types (S, HC, HCT) can drive 25mA. For these latter types you'd be rather safe with a 100Ω resistor, I'd think.
5282604
Full Member level 4
egypt
thank you :grin:
74ls164 i must to use transistor for driving led.
74(S, HC, HCT)164 direct connect with led by resistor only. max 25 MA
rfredel
Full Member level 5
Bonn, Germany
Hello 5282604,
you can use SN7407 as buffer / driver. It has open collector and can 40mA.
regards
Rainer
