Externet
Advanced Member level 2
- Joined
- Jan 29, 2004
- Messages
- 579
- Helped
- 28
- Reputation
- 58
- Reaction score
- 29
- Trophy points
- 1,308
- Location
- Mideast US
- Activity points
- 5,671
Hi.
Many years ago, found about 5cm diameter loooong steel? cables at the bottom of a bay while diving. I was told it was part of an abandoned "cable" ¿? communications system from WW2.
Were those the actual radiating elements for undersea communications, or a 'ground plane' net for a shore mounted antenna ? Or, what was their function ?
How to calculate a ferrite rod or iron rod wound antenna coil to resonate at 73 KHz, embedded in an epoxy sealed enclosure, submerged in the sea ?
A resonating capacitor to such wound coil should better be in series or in parallel to the coil for longer range ?
