d123
Advanced Member level 5
Hi!
I don't understand a difference between how the 7106 and the 7107 ADCs manage the scale and display the measured values on a 3-1/2-digit display. I have had to use a 2V scale for the 7106 to obtain the same display (is the term "resolution"?) reading I got with a 200mV calibrated 7107.
Using the same breadboard, same power supply, same circuit layout, and the exact same components, but a 7106 instead of a 7107 (and see that it needs the "jumper" from analogue common to Vin-, which the 7107 doesn't), the 7106 circuit only displayed 2 digit readings whereas the 7107 version displayed 3 digits using a 1M/10K divider.
i.e.
7107 = 1.98V/7106 = 01.9V
7107 = 5.01V/7106 = 05.0V
7107 = 8.75V/7106 = 08.7V
I changed the 7106 to the 2V full scale and now it does correctly display 3-digit readings.
I also changed the Vin+ and Vin- divider from 1M/10K150 to 10K/1K1, but I'm not so sure this has anything to do with my question as when I tested the 10:1 divider on a 200mV scale the same problem arose of the ADC not getting past a reading of approx. 2.60 on the display where it should have read 5.01. I played around with 100:1 dividers (1M/10K, 100K/1K) yesterday and the same thing kept happening with a 200mV scale calibrated to 100mV, and frankly I just don't remember if I tried a 10:1 divider then - it's all a blur of frustrated resistor swapping
Anyway...Why does the 7106 appear to require a 2V scale but the 7107 a 200mV scale to obtain the same readout result?
Thanks.
i.e.
Thanks.
