UroBoros
Advanced Member level 2
- Joined
- May 5, 2004
- Messages
- 642
- Helped
- 19
- Reputation
- 38
- Reaction score
- 8
- Trophy points
- 1,298
- Location
- Cochin - India
- Activity points
- 6,463
I need to slowly DIM and slowly make a LED brighter. The LEDs are ceiling lights may be in the range of 6W-12W. it is having a SMPS already there.
So I plan to introduce a MOSFET between the SMPS and LED which in turn will PWM'ed from a Microcontroller. This is my plan and I tried it, but the dimming is not smooth especially in the extreme low brightness area.
is there any commercial modules which can be interfaced to a micro controller for dimming leds?
1. is there any specific LED dimming ICs which can be controlled from a micro controller via SPI or IIC?
2.if we are doing PWM to dim and led using Micro controller what should be the optimum pwm period to get a smooth effect?
Thanks
edit: even if i tried the lowest possible pwm duty cycle, the led cannot be made to off in a linear fashion. is it because of the nature of LED lights or problem with MOSFET switching?
Thanks
