5.8ghz A/V transmitter+ receiver
mutcho
Newbie level 2
Newbie level 2
hi?i am very much in designing a 5.8ghz a/v transmitter and its receiver(module) and eventually prototype it in my electronics project.i need your help in:
1.the schematics....i would appreciate you sending me the schmatics.can i find equivalent ics locally.i was intending to use awi 5800.its not locally available....any suggestions?
If you intend to transmit A/V signals in digital form, no rpoblem.There may be 5.8GHz high data rate ( depending on your data rate of course A/V signal quality ) transmitters/receivers in the market.But if you transmit and receive these signals in analog mode, you cannot find anything for this purpose because 5.8GHz is not a proper standard for analog transmission.However, if you use standard A/C modulator that works at lower VHF or UHF frequencies, you can also up-convert its output to higher frequency.It's technically possible.
Reactions: mutcho
    mutcho
