4x4 keypad encoder downloaded on Altera DE2
wallywall
Newbie level 3
Newbie level 3
hello i am trying to finish my keypad encoder project. i ill be using Quartus II for simulation and the Altera DE2 board for testing. below is my vhdl code. i am stuck at defining my inputs and outputs in Quartus. Also i am stuck when it comes to assigning pins to the DE2 board. PLEASE HELP!!
LIBRARY ieee;
USE ieee.std_logic_1164.all ;
ENTITY keyencoder IS
PORT (  clk     :IN STD_LOGIC;
        col     :IN STD_LOGIC_VECTOR  (3 DOWNTO 0) ;
        row     :OUT STD_LOGIC_VECTOR (3 DOWNTO 0) ;
        d       :OUT STD_LOGIC_VECTOR (3 DOWNTO 0) ;
        dav     :OUT STD_LOGIC                    );
END keyencoder;
ARCHITECTURE vhdl OF keyencoder IS
SIGNAL Freeze       :STD_LOGIC;
SIGNAL data         :STD_LOGIC_VECTOR  (3 DOWNTO 0);
BEGIN
   PROCESS (clk)
   VARIABLE ring    :STD_LOGIC_VECTOR (3DOWNTO 0) ;
   BEGIN
      IF (clk'EVENT AND clk = '1')  THEN
         IF freeze = '0'  THEN
            CASE ring IS
                WHEN "1110" => ring := "1101";
                WHEN "1101" => ring := "1011";
                WHEN "1011" => ring := "0111";
                WHEN "0111" => ring := "1110";
                WHEN OTHERS => ring := "1110";
            END CASE;
         END IF;
         dav <= freeze;
      END IF;
      row <= ring;
      CASE ring IS
         WHEN "1110" => data(3 DOWNTO 2) <= "00";
         WHEN "1101" => data(3 DOWNTO 2) <= "01";
         WHEN "1011" => data(3 DOWNTO 2) <= "10";
         WHEN "0111" => data(3 DOWNTO 2) <= "11";
         WHEN OTHERS => data(3 DOWNTO 2) <= "00";
     END CASE;
     CASE col IS
         WHEN "1110" => data(1 DOWNTO 0) <= "00";       freeze <= '1';
         WHEN "1101" => data(1 DOWNTO 0) <= "01";       freeze <= '1';
         WHEN "1011" => data(1 DOWNTO 0) <= "10";       freeze <= '1';
         WHEN "0111" => data(1 DOWNTO 0) <= "11";       freeze <= '1';
         WHEN OTHERS => data(1 DOWNTO 0) <= "00";       freeze <= '0';
     END CASE;
     IF freeze = '1'    THEN d <= data;
     ELSE               d <= "ZZZZ" ;
     END IF;
   END PROCESS;
 END vhdl;
right - problems with your code:
1. You shouldnt mix synchronous and async logic in the same process - its bad practice.
2. If you really wanted to mix the two, you are missing several signals in your sensitivity list, so simulation wont work properly (data
But I suspect you really wanted the case statements inside the clocked part of the process.
Also, why do you set d to "ZZZZ"? It is only an out, not an inout, so you dont need a tristate buffer.
i was thinking the same but i actually got this code out of my digital systems class book! if you could believe that.
what signals am i missing?
what, in you opinion should ZZZZ be replaced with?
i compiled the code in Quartus II and compilation was Successful with a few warnings so its not entirely wrong is it?
i really need help with this
