can any help me with this? to convert a pseudocode into c program code?
set port C and port D to input(appropriate TRIS registers)
loop until port D pin 0 goes high
read port C pin0-pin3
perform look-up for the corresponding value
The pseudocode is words representing the actual programming keywords. Pseudocode tells you what the program needs to do. In this case, it is the stuff between the "{" and the "}".
char kp =0;void main(){
TRISC =0xFF;
TRISD =0xFF;while(1){while(RD0_bit ==0);
kp =(PORTC &0x0F);switch(kp){case0://do what you want herebreak;case1://do what you want herebreak;case2://do what you want herebreak;//...default:};}}
So this is the coded for
TRISC =0xFF;
