[SOLVED] 4line LCD with pic18f14k50_
pcsandhya82
Member level 3
Bangalore
I ve attached the project and ISIS schematic. LCD gets initialised, but it does not show characters. I m not able to debug it.. could someone please help?
  • LCD_18f14k50.rar
Sajjadkhan
Full Member level 5
Rawalpindi,Pakistan
Download the datasheet of this exact controller of the LCD. There you will find the correct sequence of commands to initialize LCD.
2nd do check that you have to wait for some milliseconds for the power buildup for lcd.
Shaheers
Member level 2
Islamabad,Pakistan
I seen the only problem is that
ANSEL=0; // Set output as Digital
u may add the line in ur code to set port as digital
however check the attachment, that hav solved the problem, [mikroC C program + Proteus sch]
  • LCD_18f14k50.rar
pcsandhya82
Member level 3
Bangalore
hi, i tried ANSEL=0. no better. guess the issue might be initialisation of LCD. i m not able to access your function definitions. could you please put them into the source file?
Shaheers
Member level 2
Islamabad,Pakistan
Well i have no idea about mplab I am working with MikroC C language compiler, but check the following mplab c18 Libraries file and Example #3.2.2 on page#85
MPLAB_C18_Libraries
if not works
before initialization the LCD
use
ADC_0ANA ; //for set all outputs as digital
or use
void CloseADC( void ); //for Disable the A/D converter.
pcsandhya82
Member level 3
Bangalore
hi,
It was a problem withinitialisation sequence.. thanks for all the help :)
