actor23
Member level 3
- Joined
- Dec 12, 2014
- Messages
- 56
- Helped
- 1
- Reputation
- 2
- Reaction score
- 1
- Trophy points
- 8
- Activity points
- 515
1.
I see that U1 is powered from an auxiliary winding. In order for the transformer to convey any power, M1 needs to be turned on by U1. Can U1 do this before it is powered up?
2.
Sudden load changes at Vo1 may affect output at Vo2 (and vice-versa.) It is because they draw from the same transformer. I suppose the solution is to raise both their output voltage and current.
3.
The TL431 is frequently used as an adjustable zener. Therefore you may be able to omit Z2.
If i use uc3842 can i feed it from 48V lithium-ion with a resistor as you said ?
But new concern is : in the datasheet of LT1245 there is a warning : "Do not
attempt to use Proto-boards or wire-wrap techniques to
breadboard high speed switching regulator circuits.
They will not work properly." WHY ??
But, if we can propery cabled all components as short as possible onto breadboard, i think there is no problem with that.
I liked your last design however first question i want to ask is that how to get +12V to feed 555 also +6V to opamp' non-inverting input ?
Secondly, im confused with D2 and nameless diode, 500ohm resistors connected at the secondary side of transformer ?
Thanks for all
