40x4 Lcd Not Working Help needed
but it is not working.
Where is the problem ?
We have to ask: Where is the problem?
Is the power supply correct?
Is the current consumption correct?
Is the communcation correct? (readback)
Does it get hot?
Maybe the display is all black, or all clear, or do you see black bars, or is it dim?
Or a thousand other questions.
--> Learn to give useful informations.
Klaus
Hi KlausSt
At present I am only testing in Proteus. I have also the hardware 40x4 LCD. This is the display I am having.
ERM4004SBS-1
https://www.buydisplay.com/default/character-display/40x4-character
I am attaching the original mikroBasic project. I compiled it and tested it and it works fine in Proteus. It was tested by the author on hardware. See images.
What mistake I have done in porting the code ?
  • 1423475647_i_have_to_connec_mikrobasic_pic.rar
Displays are working. So, where is the problem?
Klaus
@KlausST
The working pictures are from original mikroBasic Project. My ported project is mikroC PRO PIC project. My project is not working. It prints test in wrong lines and half of 1st and 3rd lines remain blank.
Nice, that you show us the working displays from another project...But this doesn´t help anybody.
... finally a pice of error description.
Why don´t you show us a photo of the "display with error"?
Klaus
Hi Okada;
. Seems your particular 40x4 LCD uses a different line addressing. Your wrote that it prints something (OK, in wrong lines but it can print characters), therefore the initializing is working, 'only' the line addressing is wrong.
. Try to modify the functions LCD_Red_Poz_Out_1 (and 2) and if need, also the function LCD_Chr. You need to experiment with them, or search for your LCD's datasheet which contains also the exact line addressing.
. Study this site:
. and this thread:
https://www.edaboard.com/threads/331611/#post1416183
Regards
zuisti
Here is the picture.
Addressing is correct. I have set the address in Proteus to
0x80-0xA7
0xC0-0xE7
0x80-0xA7
0xC0-0xE7
I assume the configuration of the two controllers is wrong.
The datasheet should show how they have to be configured. Either 2 x 40, or 4 x 20 mode.
There are other threads discussing problems with 40x4 displays.
Look at the box "similar threads" below.
Klaus
I again ported the original mikroBasic PRO PIC code to mikroC PRO PIC and changed a few delays and it suddenly started working. Here is the working project. Proteus file is included.
  • LCD 40x4 4-Bit Interface.rar
