naserim
Newbie level 1
- Joined
- Mar 16, 2013
- Messages
- 1
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Activity points
- 1,293
Hello guys
As a part of my school project I'm working on a 400khz power inverter. I need the output current to be 18A. supply voltage is 40V.
I've tested many circuits and I considered IR2113 mosfet driver as the solution. The inverter works well in low duty cycles while the current is about 4A however when the pulse width increases one of mosfets starts to heat up and after a few seconds all mosfets burn.
I've tested IRF3205 and IRFp150.
I'm really disappointed.
Please help me.
I've used the ir2113 datasheet circuit with 10uf caps and uf4007 diode. all Fets are Nchannel.
this is the 2113 circuit. each 2113 drives two mosfets which are turned on simultaneously. connectors are connected to high side fet gate, high side fet source and low side fet gate.
Please help me.
