Code C - [expand] |
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
201
202
203
204
205
206
207
208
209
210
211
212
213
214
215
216
217
218
219
220
221
222
223
224
225
226
227
228
229
230
231
232
233
234
235
236
237
238
239
240
| /*Program for LCD interfacing to ARM Microcontroller */
/*Robota Corporation*/
//Port 1.16-1.23 should be connected do Data pins of LCD(1.16=LSB)
//Port 0.16 should be connected to Rs pin of LCD.
//Port 0.17 should be connected to En pin of LCD.
#include<lpc21xx.h>
#include "lcd.h"
/*---------- Initialization of LCD ----------*/
void lcdinit(void)
unsigned int j;
unsigned char commands[]={0x30,0x30,0x30,0x20,0x28,0x08,0x01,0x06,0x0c},i=0;
IODIR1=0x00ff0000; //data pins
IODIR0=0x00030000; //rs=p0.16,en=p0.17
IOCLR1=0x00ff0000;
while(i<9)
delay_lcd();
lcdsendcommand(commands[i]);
i++;
/*---------- Delay for LCD function ----------*/
void delay_lcd()
unsigned int i;
for(i=0;i<1000;i++);
/*---------- Sending Command to LCD -----------*/
void lcdsendcommand(unsigned int cm)
cm=cm&&0xF0; //High Nibble
cm=cm<<16;
IOCLR0|=0x00010000; //RS =0 for Command.
IOCLR1|=0x00ff0000;
IOSET1|=cm;
IOSET0|=0x00020000;
delay_lcd();
IOCLR0|=0x00020000;
delay_lcd();
// Low Nibble
cm=cm&0x0F;
cm=cm<<4;
cm=cm<<16;
//IOCLR0|=0x00010000; //RS =0 for Command.
IOCLR1|=0x00ff0000; // check1 here
IOSET1|=cm;
IOSET0|=0x00020000;
delay_lcd();
IOCLR0|=0x00020000;
delay_lcd();
/*---------- Sending character to LCD ----------*/
void lcdsendchar(unsigned int ch)
ch=ch&0xF0;
ch=ch<<16;
IOSET0|=0x00010000; //RS=1 for Data
IOCLR1|=0x00ff0000;
IOSET1|=ch;
IOSET0|=0x00020000;
delay_lcd();
IOCLR0|=0x00020000;
delay_lcd();
ch=ch&0x0F;
ch=ch<<4;
ch=ch<<16;
// IOSET0=0x00010000; //RS=1 for Data
IOCLR1|=0x00ff0000;
IOSET1|=ch;
IOSET0=0x00020000;
delay_lcd();
IOCLR0=0x00020000;
delay_lcd();
/*---------- Sending LCD String ----------*/
void lcdsendstring(unsigned char *name)
while(*name!='\0')
lcdsendchar(*name);
name++;
/*---------- Sending number to LCD ----------*/
extern void lcdsendnumber(unsigned int n)
//conversion of HEX to ASCII---simple//
unsigned char a,b,c,d;
d=n%10;
n=n/10;
c=n%10; //converting Hex in decimal
n=n/10;
b=n%10;
n=n/10;
a=n%10;
d+=0x30;
c+=0x30; //converting decimal in ASCII.
b+=0x30;
a+=0x30;
lcdsendchar(a);
delay_lcd();
lcdsendchar(b);
delay_lcd();
lcdsendchar(c);
delay_lcd();
lcdsendchar(d);
lcdsendchar(0x41);
/*---------- Setting position of LCD ----------*/
void lcdposition(unsigned char LINE,unsigned char pos)
if(LINE==1)
lcdsendcommand(0x80+pos);
else if(LINE==2)
lcdsendcommand(0xC0+pos);
/*---------- Clearing LCD Screen ----------*/
void lcdclear(void)
lcdsendcommand(0x01);
I need to interface 16x2 lcd to ARM LPC2148 , PLEASE SEE THE ABOVE CODE FUNCTION
lcdinit(); where I am sending commands 0x30,0x30,0x30,0x20,0x28,0x08,0x01,0x06,0x0c
, also check delay_lcd() function,
my LCD showing garbage characters in 4 bit mode , I have done parsing of upper nibble in lcdsendcommand(); and lcdsendchar(); functions...
please suggest..
