3rd Order Non-Linearity RF question
steppermotor
Newbie level 6
I read that the second-order non-linearity could affect the DC offset, but does the third order non-linearity also affect the DC offset?
Also was wondering are these due to 3rd order nonlinearity:
- P1db due to signal itself
- p1db due to strong blocker (I'm not sure I understand the concept of the blocker perfectly I've read up on it and I know blockers cause the gain compression)
No, because if you perform Fourier transformation, you will see that just the second harmonic has a dc-component!
What do you mean with blocker?
I would call a blocker a spurious signal that shows up at the input.
