Anomis
Junior Member level 3
- Joined
- Mar 11, 2017
- Messages
- 29
- Helped
- 5
- Reputation
- 10
- Reaction score
- 4
- Trophy points
- 1,283
- Location
- South Korea
- Activity points
- 1,575
Hello my friends,
I am trying to drive a 350 watt,3phase, BLDC motor (DGW07-20j model) with stm32 micro controller. But I have problem with hall sensors because their outputs are not similar to the hall sensors which I have seen on the internet.
I connected the sensor supply to +5v dc (according to the sensor pcb guide). Then I connected two of hall sensor outputs (2of3) to the oscilloscope channels which is shown in the following picture.
Unfortunately, I couldn't find the model number of hall sensor or related data-sheet. But I connected the supply and outputs based on printed pinout guide on pcb. You can see these connections in this picture...
The motor was working while I captured the hall sensor outputs but clearly not not in a good way because the switching phase timing should be adjusted using hall sensor outputs.
![photo5938057484226899319.jpg photo5938057484226899319.jpg](https://www.edaboard.com/data/attachments/81/81722-9171919ae2cd7e65fa6f329a3276fa10.jpg)
![photo5938057484226899320.jpg photo5938057484226899320.jpg](https://www.edaboard.com/data/attachments/81/81723-d293cca235724d1309e98e1cc664881d.jpg)
![photo5938057484226899318.jpg photo5938057484226899318.jpg](https://www.edaboard.com/data/attachments/81/81726-6cea9e4c9a292c7c835f37d9ce1fccee.jpg)
