I want to simulated efficiency and output power of a PA by 3G modulated signal. Can anyone tell me which kind of signal source or test bench should be used? I want to simulate them by Harmonic Balance simulation, not in system level. Thanks!
I think you are right. I found from examples\RF_Board\NADC_PA_prj a similar example, it uses envelop simulation.
But can you tell me are there any predefined test bench or source in ADS for efficiency simulation in 3G modulated signal?
The 3GPPFDD_UL_Source element is too complex, there are too much parameters. I have no knowedge in system level design. And I think there should be a easier method.
