How to control or switch AC supply?
RETGT
Banned
Hello,
I can switch on off ac supply with relay but now i want to change method like fast switching as led bulb or halogen any thing motor
please tell any method to do this??
Triac Switching is the best method.
Reactions: RETGT
    RETGT
If you do a quick search on the internet, you will see that the alternative for fast switching compared to electromechanical devices is the use of silicon switching components. A more efficient way to achieve a more precise pulse control would be by first rectifying the AC voltage, and then controlling via DC by transistors.
Reactions: RETGT
    RETGT
Hello World,
I want output to be AC not DC
Which triac to use sir?
any part number?
Ok, so your control will need to be synchronized with the phase of the electric mains, namely the zero-cross current. You can search on the Web for the keyword Dimmer. Will find a lot of examples.
Reactions: RETGT
    RETGT
ok thanks i will try
BTA 10 is 10A rated triac at 600-800VAC max what is your wsitching current required?
BTA 41/600B is 40A @600VAC
Reactions: RETGT
    RETGT
i want to control transformer 12V 1Amp output.
Square wave just on/off...
