eepty
Full Member level 2
I found some circuit has pull down resistor between IC's input pin and the ground, but some other circuit tie the pin directly to ground.
I would like to ask is the pull down resistor needed? Any pros and cons?
(Assume cost is not an issue)
Thanks!
Thanks!
