[Moved]: Break circuit into two half circuits
anhnha
Full Member level 6
Could you prove this sentence from a paper in the image below:
"Since the circuit is fully symmetric, it can be broken into two half circuits, like the one shown in Figure 5."
Re: Break circuit into two half circuits
I think it'm simple that Vx=Vx/2-(-Vx/2). after they analyze the circuit in Figure 5.
Reactions: sarge
    sarge
You can break the Vin signal with 0V on the middle node. Using the KVL, the voltages at the input terminal are +Vin/2 and -Vin/2
Reactions: anhnha
    anhnha
How can you know that the potential at the point between two voltage sources is 0V?
BTW, could you talk detail how would you apply KVL here?
I know KVL but I don't know how you use it here.
The circuit is symmetric, so the average voltage between the two circuits will be zero. VL-0=Vx/2 gives VL=Vx/2 and 0-VR=Vx/2 gives VR=-Vx/2.
Well, could you prove how the potential at the point between two voltage sources is 0V?
The middle node becomes a virtual ground (not actual ground) when left and right hand side of a differential circuit are same. Analyze the half circuit, and then multiply by 2 at the end to get the overall response.
