16x80 dot matrix display
jigarpatelp
Junior Member level 2
Vadodara,Gujarat,India
It's a two line display and character size is 8x8.
while in first 10 character are scrolling from left to right and stays static until next 10 character scroll in second line.
I'm able to scroll both in lines and show static image but unable to programme first line to stay static until second line completed.
Please Help me.
can u update the source you are using (code/compiler)
No one can help you without your source.
Attach the entire project folder (in a RAR) and the used Proteus DSN file (max. v7.10 please).
A note: instead of the 4 * hc138 use only one hc154 like me:
https://www.edaboard.com/threads/11364/#post1027308
(this is a 2-sheet DSN !!)
I've attached my project .
see attachments
I'm using mikroc pro compiler with pic18f4520
  • Multiline.rar
Your code was modified only to the extent necessary, but so now it works (in Proteus) the way you want.
Minor changes, for ex:
- eliminated unnecessary variables
- all unsigned int (16-bit) variables are changed to char (8-bit)
- the CharData array is moved to a separated .H file
- added indentations: better readable code
- simplified DSN file, but it uses the COF (not the HEX) file so it is debuggable
But:
The code is not enough efficient (sorry), so have to working on it (lot).
For example:
- too complicated so too slow row-shift function
- different row-display time: different row-brightness in the reality
- too small row-display time slices: very low real brightness
- too small refresh rate
and so on.
Sincerely:
zuisti
  • Multiline_mod.rar
so how to inprove my codes efficiency,led brightness,and cost effective.
Share you ideas and changes i'll do it.
Thank you
OK, for an example use a separated, stand-alone display function (full, for all rows) with interrupt controlled timing, and also separated scrolling routines.
But do not wait for a solution from others, find it (even here in our forum). E.g. study the large "DIY Moving Message Display" thread, here are a lot of useful solution, can be adopted - with appropriate modifications - in your case.
I also wrote such things in the past, look at them, can be useful (though they may continue to be improved, now I would write better code, especially the "shift_in_a_column" routine).
For example:
https://www.edaboard.com/posts/1125963/#post1125963
and
https://www.edaboard.com/posts/1148762/#post1148762
I know that almost all examples use only one-line display, but the logic (the algorithms) can be used for the two-line display also.
Good luck!
zuisti
PS:
Friendship? It's too early ... yet. Sorry.
but how to calculate timing function and all other function.
Please attach equations for all of the calculation for designing a efficient dot matrix display for any size.
