32-bit CPU in non-BGA package?
davorin
Advanced Member level 3
Switzerland
Anyone using a powerful 32-bit CPU supported by (uC)Linux which is available in normal (T)QFP package?
Since there is no more SA1x00 on stock I think of replacing the mainboard of Tuxscreen (o;
Check V850 from NEC
www.ee.nec.de
You can download 30 day trial C compiler froim IAR.
Also if you get N-Wire Card you will receive 64 KB limited IAR package.
Regards ,
Elvis
How about the Atmel AT91RM9200 (ARM 920 based).
It's available in QFP.
Very reasonably priced in low quantities and stuffed with peripherals.
Cogent do a low cost development board based on these (CSB337 or might be CSB377?) which runs micromonitor.
Linux runs fine on the chip though - info can be found on the Atmel CD's.
ARM7 s3c4510(QFP208)
Philips LPC21xx seires
Analog Devices ADuc7xxx
