E-design
Advanced Member level 5
One of my friends recently approached me with something puzzling about the reverse breakdown voltage of some LED's.
He bought some cheap bulk 5mm red and green LED's from China and decided to measure the characteristics on his curve tracer.
What he found surprised him. Most data sheets show the reverse breakdown voltage to be in the region of 4-7V.
The red LED's that he tested broke down at approximately 35V and the green at about 124V.
When he informed me, I thought that he was not reading a scale correctly or something. Well, he gave me a visit and brought some of these LED' along.
I tested it on my Tektronix 577 curve tracer and got the same readings. The forward readings were normal around 1.8V for the green and 1.5V for the red.
I then did some search on the Internet and found someone who had a similar experience with an even higher breakdown voltage of 185V.
Anyone here had a similar experience?
https://www.tablix.org/~avian/blog/archives/2009/11/reverse_biased_led/"The diode started conducting a significant current at 185 V (which, by the way, is surprisingly high as all datasheets I've seen rate such LEDs at maximum 5 V reverse bias)"
