Hello All,
I have designed a 300 GHz lens antenna and I want to test it. I have ordered its fabrication and its very small, it has to be attached with a lens and a PCB to hold it.
I have to measure s-parameters and radiation pattern. The antenna chip will also have detector mounted.
I want to order an antenna positioner/rotator for radiation pattern measurement.
Can anyone please suggest a company for an accurate (around 0.1 to 0.05-deg accuracy) rotator/positioner for antennas at 300 GHz frequency range?
The rotator would be for both azimuth and elevation planes.
Our measurement system has everything required, except a motor/automatic rotator for PCB/antenna.
Thank you in advance.
