Hi, I design one PWM 3-phase inverter, I add 4 four loads(3 with switches), but the current curve shown in scope 2 looks not good, if there's anyone help me to improve the current curve, that makes it smoothy?
Hi, Brad, thank your for your replying
What you have mentioned is one part of my problem, besides, I want the curve to be like the sinusoid(the image shown below but ignore the value).
I have tried to replace the 'resistor' load with the 'resistor parallel with inductor' load, and the schematic looks better, but the value of the current is too big(around 3000A).
I want to figure out the how to choose the components for the load and how to set the value of those components.
Three-phase.
Four different loads.
You have a lot going on here.
Did you try a basic schematic of your system? With one phase? One load? Etc.
2.
It would help if you were to provide timing diagrams of your gate-driving waveforms.
3.
It is not clear as to how your LC filters interact. What do you understand to be the path of current through them? Are they supposed to have a connection to ground?
4.
The LC values must be selected to go with your load and operating frequency (or low pass frequency).
The inductor has a reactive impedance. It needs to be calculated so its impedance is in the vicinity of your load.
The basic inverter topology is correct, except for one important point. You must not ground the bus voltage and the load center point at the same time.
But using a correct topology doesn't ncessarily mean that the control signals and filter parameters are appropriate.
