suri007
Newbie level 5
- Joined
- May 3, 2013
- Messages
- 8
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Activity points
- 1,360
Hello,
I am working on 3 phase IGBT inverter project in unbalanced condition so that i can use the Phases independently. As the Load would not be a Motor and i am using 3 phases independently to control 3 resistive loads (bulbs) I know to generate a Neutral point at the output common for three phases.
Below are my queries
1) From where should i take the Neutral point / How to generate the Neutral point if there is any pre-existing method
2) Design of LC filter - How to select it for an Output freq of 50HZ
3) The capacitor one end will be connected to Inductor, Other end of capacitor should be connected to which point?
I hope you guys can help me over come this problem
Regards,
Suresh
Regards,
Suresh
