[SOLVED] DS1307 with ATmega32
remona
Khartoum, Sudan, Sudan
Hello All
i am working on RTC DS1307 interface with ATmega32
i am using built in library of DS1307 in CodeVision AVr.
i cannot set the day of week
can we help me Please :roll:
What problem u face is default day consider or any other please mentioned
Reactions: remona
    remona
i can not read and set the day of week ,i was used
day=i2c_read(0)& 0x07; to read the content of RTC register "day" and always i have number 7
and used
i2c_start(); //transmit start cpndition
i2c_write(0b11010000); //transmit addres od DS1307 +w
i2c_write(0x03);
i2c_write(day & 0b00000111); //set day of weak
delay_ms(20);
i2c_stop();
i never get that day i was entered
Try by Write address D3 only instead of 0d & 03 .then write day data
Reactions: remona
    remona
what r u means by D3??????????????
In each case i was try that
if i lay day=5 then used
i2c_write(0x03); //set register pointer to 03
i2c_write(day); //set day of week "day value"
delay_ms(20);
i2c_stop();
to read day of week used day=i2c_read(3)& 03;
always day =3
Try This
i2c_start();
i2c_write(0b11010011);
i2c_write(0b00000111); //set day of weak
delay_ms(20);
i2c_stop();
if it work or not
inform result
Try This
i2c_start();
delay_ms(20);
i2c_stop();
if it work or not
inform result
Reactions: remona
    remona
The objective of the project to give the user the possibility to adjust the day to receive the value of it
So I need to write on the Registrar then read the Registrar to test result
But in the code sender value of each day is always fixed by 3
i2c_write (0b00000111); / / set day of weak
From above I guess like this
1. User always set Day as per his choice. so u required day setting. I suggest first check whether logic work for any day value which may 1 to 7 . for this u set fix value check if it work then u change ur logic.
2. In code sender u say always fixed value =3 but in write command u write 0x00000111 which = 0x07 so which is correct
Reactions: remona
    remona
Unfortunately, I tried and did not get any satisfactory result
What's supposed to work I am doing :sad:
Thank you a lot for you try to help me, finally ,I was resolved the problem and got the desired results, interest permeated i was used :
/* set Day of weak from DS1307 */
i2c_write(0xD0); //transmit addres od DS1307 +w
i2c_write(0x03); //set Dregister pointer to 03
i2c_write(day); //set day of weak
delay_ms(20);
i2c_stop();
/* Read current "Day" from DS1307 */
i2c_start();
i2c_write(0xD0); // transmit addres od DS1307 +w
i2c_write(0x03); // set register pointer to 3
i2c_start();
i2c_write(0xD1); // RD from RTC
day = i2c_read(0)& 07; // Read current "Day" in DS1307
i2c_stop();
Thanks alot :smile:
u problem is with just bit which is 3 instead of 7 may correct. Just try for D3 instead of seperate D & 3
