[SOLVED] Why Serial Transmit is not working?
Hello! I want to know why serial transmit is not working?
#include<reg51.h>
#include<string.h>
//Function declarations
void cct_init(void);
void delay(int);
void lcdinit(void);
void writecmd(int);
void writedata(char);
void ReturnHome(void);
void display();
void display2();
void send_uart(void);
void send_string_uart(unsigned char string[]);
//Pin description
P2.4 to P2.7 is data bus
P1.0 is RS
P1.1 is E
// Defines Pins
sbit RS = P1^0;
sbit E  = P1^1;
unsigned char card_id[12];
unsigned char tag[12] = { 49, 50, 51, 52, 53, 54, 55, 56, 57, 49, 50, 51 };
unsigned char read_id[12];
unsigned char current_byte = 0;
unsigned int display_flag = 0;
unsigned int key = 0;
unsigned int count = 0;
unsigned char mystring[] = "AT89C51";
void recieve() interrupt 4     //Function to recieve data serialy from RS232
        card_id[current_byte]=SBUF;
        RI=0;                // Reset the serial interrupt after recieving the byte
        current_byte++;
// Main program
void main(void)
	 cct_init();                                     //Make all ports zero
	 TMOD=0x20;                            //Enable Timer 1
   TH1=0XFD;
   SCON=0x50;
   TR1=1;
   EA=1;
   ES=1;
	 lcdinit();                                      //Initilize LCD
   writedata('U');                                 //write
   writedata('n');                                 //write
   writedata('i');                                 //write
   writedata('q');                                 //write
   writedata('u');                                 //write
   writedata('e');                                 //write
   writedata(' ');                                 //write
   writedata('C');                                 //write
   writedata('a');                                 //write
   writedata('r');                                 //write
   writedata('d');                                 //write
	 writedata('I');                                 //write
   writedata('d');
   ReturnHome();                                   //Return to 0 position
	while(1)
		while(current_byte!=12);
		display();
		delay(500000);
		key=0;
		for(count=0;count<12;count++)
		   if(card_id[count]==tag[count])
			 key++;
		count = 0;
		if((key == 12) && (display_flag == 0)) {
				delay(500000);
				display2();
			  display_flag = 1;
			  key = 0;
		send_uart();
		send_string_uart(mystring);
		if((tag == card_id) && (display_flag == 0)) {
			  display2();
			  display_flag = 1;
void send_uart(void) {
	TI = 0;
	SBUF = 'A';
	while(TI == 0);
	delay(500000);
void send_string_uart(unsigned char string[]) {
	unsigned int count;
	for(count = 0; count < strlen(string); count++) {
		TI = 0;
		SBUF = string[count];
		while(TI == 0);
		delay(500000);
void display()        // Function to display the unique id
    unsigned char count;
    writecmd(0xC1);        //Place cursor to second position of second line
				          writedata(card_id[count]);
									//read_id[count] = card_id[count] + 48;
    current_byte=0;
void display2()        // Function to display the unique id
    //unsigned char count;
    //for(count=0;count<12;count++)
				    //writedata(tag[count]);
						writedata('A');                                 //write
						writedata('c');                                 //write
						writedata('p');                                 //write
						writedata('t');                                 //write
void cct_init(void)
P0 = 0x00;   //not used
P1 = 0x00;   //not used
P2 = 0x00;   //used as data port
P3 = 0x00;   //used for generating E and RS
void delay(int a)
   int i;
   for(i=0;i<a;i++);   //null statement
void writedata(char t)
   RS = 1;             // This is data
   P2 &= 0x0F;		   // Make P2.4 to P2.7 zero
   P2 |= (t&0xF0);     // Write Upper nibble of data
   E  = 1;             // => E = 1
   delay(150);
   E  = 0;             // => E = 0
   delay(150);
   P2 |= ((t<<4)&0xF0);// Write Lower nibble of data
   E  = 1;             // => E = 1
   delay(150);
   E  = 0;             // => E = 0
   delay(150);
void writecmd(int z)
   RS = 0;             // This is command
   P2 |= (z&0xF0);     // Write Upper nibble of data
   E  = 1;             // => E = 1
   delay(150);
   E  = 0;             // => E = 0
   delay(150);
   P2 |= ((z<<4)&0xF0);// Write Lower nibble of data
   E  = 1;             // => E = 1
   delay(150);
   E  = 0;             // => E = 0
   delay(150);
void lcdinit(void)
  ///////////// Reset process from datasheet /////////
     delay(15000);
	 P2 |= (0x30&0xF0);    // Write 0x3
	 E  = 1;               // => E = 1
	 delay(150);
	 E  = 0;               // => E = 0
	 delay(150);
     delay(4500);
	 E  = 1;               // => E = 1
	 delay(150);
	 E  = 0;               // => E = 0
	 delay(150);
     delay(300);
	 E  = 1;               // => E = 1
	 delay(150);
	 E  = 0;               // => E = 0
	 delay(150);
     delay(650);
	 P2 |= (0x20&0xF0);    // Write 0x2
	 E  = 1;               // => E = 1
	 delay(150);
	 E  = 0;               // => E = 0
	 delay(150);
	 delay(650);
   writecmd(0x28);    //function set
   writecmd(0x0c);    //display on,cursor off,blink off
   writecmd(0x01);    //clear display
   writecmd(0x06);    //entry mode, set increment
void ReturnHome(void)     //Return to 0 location
  writecmd(0x02);
    delay(1500);
  • serial tx.rar
probably because your uart is not initialized?
sure there's no uart_init() function?
and where does this set the baud rate and such?
Here is the Timer Initialization and UART Initialization
   TH1=0XFD;
   SCON=0x50;
   TR1=1;
   EA=1;
   ES=1;
The Uart Receiving in working fine. Transmit is not working. In the virtual terminal you have to type 123456789123 then it displays Card Accepted in LCD, then only it transmits 'A' and "AT89C51" to uart.
because there is no isr routine........
u have enabled the serial interrupt but u are not handling it...........
look u have enabled the serial interrupt.......
EA=1;
   ES=1;
where is serial interrupt service in ur program
Yes. It is working after I changed P3.0 and P3.1 to 1 i.e., P3 = 0x03.
major error fixed.
here is the working file.
  • rfid reader v3.rar
