How to design a low-voltage to high-voltage level shifter?
lokeyh
Level shifter
I need to design a low-voltage to high-voltage level shifter. Is there any recommended ebooks or papers on the designing of low-voltage to high-voltage level shifter? Any recommendations on the architecture for level shifter?
Thanks in advance.
Re: Level shifter
What voltages are required ?
See attached jpeg for 1.8V to 5V up convertor
Reactions: orient
    lokeyh
    orient
Level shifter
Use above CKT. please pay attention the positve feedback and latch the voltage
Re: Level shifter
How much high-voltage level shifter we are talking about? If it is in ranges of 5-100volts use a power opamp and if more I suggest you to use a transformer.
Level shifter
Hi, yeewong_su,
Can you provide more in detail about those stuffs?
Thanks in advance
Re: Level shifter
I am asking in terms of IC design. The problem with the circuit provided by yeewong_su is that it depends on how low the 1.8V can go. if the 1.8V goes down to 0.8V, the thick-oxide NMOS at the 2.5V portion will not be able to pull the signal low. Is there any other circuits?
Re: Level shifter
Hi Colbhaidh,
I will try the design.
Hi all,
Are there other architectures for level-shifter?
Re: Level shifter
If your siganl come from NMOS transitor you can use PMOS common drain circuit to obtain high voltage level shift
Re: Level shifter
how about to mirror current? Use NMOS for mirroring. It works but I can't show the structure.....
Re: Level shifter
This also depends on how fast the signal goes, and how much load needs to be driven. I assume the input is a digital signal while the output is to control analog circuitry. The cross coupled structure can work up to MHz range. If higher speed is needed, may need to cascade a few inverters.
Re: Level shifter
any reference books talk about?
i want to learn how to design also
= p
Level shifter
It is quite interesting to read the low-voltage to high voltage level shifter . But I meet a problem. I need to design a 1Gbps to several Gbps PECL output buffer, the traditional source follower's efficiency is too low . Is there any good alternative choice?
Re: Level shifter
What is the speed of your level shifter?
For the frequency under 300MHz for 0.18um CMOS process, you could use the simple circuit with 2 PMOS latch and 2 NMOS .
Re: Level shifter
The <<CMOS :CIRCUIT DESIGN, LAYOUT, AND SIMULATION >>
By R.J Baker etc.
PP 370 .
