internetuser2k12
Banned
Hello!
The resistors connected to 555 should be 730 Ohms each, but if I make it 730 Ohms, the ADC doesn't work. If I make the resistor values 10K it works, but the adc readings are not correct on varying the temperature of LM35. What is the problem?
The code is like this
// LCD module connections
sbit LCD_RS at P3_0_bit;
sbit LCD_EN at P3_1_bit;
sbit LCD_D4 at P3_2_bit;
sbit LCD_D5 at P3_3_bit;
sbit LCD_D6 at P3_4_bit;
sbit LCD_D7 at P3_5_bit;
// End LCD module connections
#define ADC_SC P2_6_bit // set the start pin to P2_0
#define ADC_EOC P2_7_bit // set the End of Conversion to p2_1
#define ADC_OE P2_5_bit // set the output enable to p2_2
#define ADC_ALE P2_4_bit // aet the Adress Latch Enable to P2_4
#define ADD_A P2_2_bit
#define ADD_B P2_1_bit
#define ADD_C P2_0_bit
#define ADC_DATA P1 // set the 8-bit data to p0 port.
void adc_init();
unsigned char adc_getdata();
double d_adc_val;
unsigned char getdata, adc_val;
char str_adc_val[17];
char txt1[] = "A Project by";
char txt2[] = "Smitha B T";
Initialize the adc
void adc_init();
void adc_init() //
ADC_EOC = 1;
//P1 = 0xFF;
ADC_ALE = 0;
ADC_OE = 0;
ADC_SC = 0;
ADD_A = 0;
ADD_B = 0;
ADD_C = 0;
Delay_ms(2);
Get the data from ADC
unsigned char adc_getdata(void);
ADC_ALE = 1; // enable ALE
Delay_ms(2);
ADC_SC = 1; // Start the ADC conversion
Delay_ms(1);
ADC_ALE = 0;
Delay_ms(1);
ADC_SC = 0;
Delay_ms(1);
// Waiting for Conversion end
while(ADC_EOC == 1);
while(ADC_EOC == 0);
ADC_OE = 1; // set the Output Enable
Delay_ms(1);
getdata = ADC_DATA; // Get the ADC data
ADC_OE = 0; // clear the Output Enable
return getdata;
void main(){
Lcd_Init(); // Initialize LCD
Lcd_Cmd(_LCD_CLEAR); // Clear Display
Lcd_Cmd(_LCD_CURSOR_OFF); // Cursor off
LCD_Out(1,3,txt1); // Write text in first row
LCD_Out(2,4,txt2); // Write text in second row
Delay_ms(2000); // 3 sec delay
adc_init();
while(1) {
adc_val = adc_getdata(); // read adc input and assign the value to adc_val
d_adc_val = adc_val * 0.588235524798245;
FloatToStr(d_adc_val, str_adc_val); // convert adc_val to string
Lcd_Out(1,3,"Temperature"); //
Lcd_Out(2,3,str_adc_val); // Display adc value
