[SOLVED] 25lc512 serial/parallel port programming
reik
Junior Member level 3
hi all, i have a 25lc512 serial spi eeprom and i wish to program it through my pc. I know there is PonyProg, but firstly i cant find 25lc512 on the list so i am not sure whether it can be supported by it or not, secondly the Si-prog software is not supported for windows VISTA/window 7.
1. is there any other way can program the 25lc512 eeprom from pc?
2. if using the ponyprog serial port, can i straightly use serial to usb converter since there is no serial port for laptop.
if using the ponyprog serial port, can i straightly use serial to usb converter since there is no serial port for laptop. Yes, but you need to make sure that the converter uses ftdi chips. There is a cheaper version that will not work.
---------- Post added at 05:48 ---------- Previous post was at 05:47 ----------
You should be able to program it using pickit 2 or some pickit 2 clone.. :) uses USB.
Reactions: reik
    reik
thanks! u get me idea about pickit2 clone! the cost is cheap somemore ! There is no different between the clone 1 and the original 1 right?
