RTC using DS1307 with pic18f452 and pic18compiler.
jaya krishna
Member level 1
India,coimbatore
i want to display the date and time to LCD....
i dont know to how to read and write I2C... the below program is executed...but output is not worked
pls somebody help me...or give some code based on pic18 compiler...
#include<p18f458.h>OR <P18F452.h>
unsigned char SPI(unsigned char mybyte);
void TRANS(unsigned char mychar);
void main()
int c;
SSPSTAT=0x00;
SSPCON1=0x22;
TRISC=0x00;
TRISCbits.TRISC4=1;
TRISCbits.TRISC7=1;
TXSTA=0x20;
SPBRG=15;
RCSTAbits.SPEN=1;
TRANS(0x0A);
TRANS(0X0D);
while(1)
PORTCbits.RC2=1; //start single byte write
SPI(0x8F);
SPI(0x00);
PORTCbits.RC2=0; // end single byte write
PORTCbits.RC2=1;
SPI(0x80);
c=SSPBUF;
SPI(0x55);
SPI(0x58);
SPI(0x16);
SPI(0x03);
SPI(0x19);
SPI(0x10);
SPI(0x05);
PORTCbits.RC2=0;
PORTC=c;
TRANS(0x0D);
SSPBUF=mybyte;
while(!SSPSTATbits.BF);
return SSPBUF;
while(!PIR1bits.TXIF);
TXREG=mychar;
thanks
jai
void main()
int c;
SSPSTAT=0x00;
SSPCON1=0x22;
TRISC=0x00;
TRISCbits.TRISC4=1;
TRISCbits.TRISC7=1;
TXSTA=0x20;
SPBRG=15;
RCSTAbits.SPEN=1;
TRANS(0x0A);
TRANS(0X0D);
while(1)
SPI(0x8F);
SPI(0x00);
PORTCbits.RC2=1;
SPI(0x80);
c=SSPBUF;
SPI(0x55);
SPI(0x58);
SPI(0x16);
SPI(0x03);
SPI(0x19);
SPI(0x10);
SPI(0x05);
PORTCbits.RC2=0;
PORTC=c;
TRANS(0x0D);
SSPBUF=mybyte;
return SSPBUF;
TXREG=mychar;
thanks
jai
no routine for LCD in your code
https://adf.ly/4116/pic-lesson-set-time-and-date
look at this site for reference
first i try to display in hyper terminal but it not displaying...so i want try to display on LCD...its possible....i m beginner ...pls help me...
how to change 24 hour to 12 hour can u help me..... thanks....
#include "16F877A.h"
#use delay(clock=4000000)
#fuses NOWDT,XT, NOPUT, NOPROTECT
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7)
#include "ds1307.c"
void main(void)
int8 sec,min,hour,day,date,month,year,pm;
delay_ms(50);
init_ds1307(); // initial DS1307
//sec=read_ds1307(0);
//write_ds1307(0,sec & 0x7F); // enable oscillator(bit 7 =0)
write_ds1307(2,hour & 0x3F); // extract the hour in BCD
while(true)
sec=read_ds1307(0); // read second
min=read_ds1307(1); // read minute
hour=read_ds1307(2); // read hour
day=read_ds1307(3); // read day
date=read_ds1307(4); // read date
month=read_ds1307(5); // read month
year=read_ds1307(6); // read year
putc(0x0c);
printf("Time : %X:%X:%X\r\n",hour,min,sec);
printf("Day : %02X\r\n",day);
printf("Date : %X/%X/%X\r\n",date,month,year);
delay_ms(500);
PHP:
#define DS1307_SDA PIN_C4
#define DS1307_SCL PIN_C3
#use i2c(master, sda=DS1307_SDA, scl=DS1307_SCL)
// initial DS1307
void init_DS1307()
output_float(DS1307_SCL);
output_float(DS1307_SDA);
// write data one byte to
// DS1307
void write_DS1307(byte address, BYTE data)
short int status;
i2c_start();
i2c_write(0xd0);
i2c_write(address);
i2c_write(data);
i2c_stop();
i2c_start();
status=i2c_write(0xd0);
while(status==1)
i2c_start();
// read data one byte from DS1307
BYTE read_DS1307(byte address)
BYTE data;
i2c_start();
i2c_write(0xd0);
i2c_write(address);
i2c_start();
i2c_write(0xd1);
data=i2c_read(0);
i2c_stop();
return(data);
PHP:
---------- Post added at 18:23 ---------- Previous post was at 18:21 ----------
PHP:
 hi .................how to change 24 hour to 12 hour by using  DS1307...
