mtxx
Junior Member level 3
Good day everyone.
I'm would like to measure the S parameters of a thin specimen, which is my DUT.
i sandwich it between 2 Xband waveguides and measured its S parameters using a VNA.
knowing that calibration is required, i chose the TRL calibration.
I've read alot of TRL info on the web, and numerous agilent application notes.
They all have something in common, which it they only mention what T,R & L means.
they do not provide the next step which is how to use these information to get the calibrated S parameters,
anyway, when measuring the S parameter of my DUT, i also measured the S parameters of my TRL standards.
since i'm using waveguides,
T: i connect both waveguides directly.
R: attach a shorting plate to both waveguide
L: i tried 2 types of line standard in case one of them is not correct, a fix attenuator waveguide, a flap attanuator waveguide.
So now i have the S parameters (S11,S12,S21,S22) of the DUT, T,R,&L standards.
i would like to perform the calculations to convert my DUT uncalibrated S parameters to the calibrated S parameters.
I've search all over the web, and read alot of research papers from IEEExplorer, science direct,
but all of them did not mention how they do it. most of the researchers used the TRL method, and the paper they quote from is
“Thru-Reflect-Line”: An Improved Technique for Calibrating the Dual Six-Port Automatic Network Analyzer
by author GLENN F. ENGEN,
i've read this paper, and did not find any steps involved on how to use the TRL s parameters to do the calibration.
Finally i found a book written by Pozar, "microwave engineering"
the one i'm reading is the 2nd edition. on page 217-221 there is a very detail explaination on how TRL works, and how it should be done.
it goes like this, the entire setup is represented as bellow
VNA port1---error box1---DUT---error box2---VNA port2
the DUT is replaced with a Thru standard, and a signal flow chart is formed
the same is done for the Line and Reflect standard.
from the signal flow chart of the T,R,L, 5 equations with 5 unknowns are obtained
the 5 unknowns are S11,S12,S22 of the error box, the propagation constant, and the reflection coefficient.
do note that there is a mistake in equation 4.77a, this mistake is not corrected in the 3rd and 4th edition of the book.
equation 4.77a is obtained by inserting equation 4.74b into 4.76b and simplified it.
equation 4.74b:
T12 = S12^2 / (1-S22^2)
equation 4.76b
L12 = S12^2 * e^(-gamma*L) / 1 - S22^2 * e^(-2*gamma*L)
equation 4.77a (as stated in the book, the WRONG one)
L12*e^(-2*gamma*L)-L12*S22^2 = T12*e^(-gamma*L) - T12* S22^2 * e^(-gamma*L)
equation 4.77a (The correct one)
L12*-L12*S22^2 * e^(-2*gamma*L)= T12*e^(-gamma*L) - T12* S22^2 * e^(-gamma*L)
have a look at the above equations, its a careless mistake in the left hand side of the equation 4.77a.
the term e^(-2*gamma*L) is placed at the wrong location.
after correcting the mistake, i used MATLAB to solve it.
there will be many answers, but the correct one will be the one that satisfied this condition,
both the real and imaginery terms of the propagation constant must be positive.
now here is the problem.
in half of the results i got, they dont satisfy this condition.
i ignored the ones that does not satisfy the condition, and only take the data that does.
but the final output i got, quite a number of the S11 and S22 parameters are larger than 1.
which i know is not possible, meaning that the calibration calculations are wrong.
what am i doing wrong here, are my TRL standards incorrect? or pozar's method is incorrect?
i've done many reading, and still searching for a correct way to do the TRL calibration.
my friend recomend me to try asking in this forum. i hope you guys will give me some idea.
its strange that such a famous method TRL calibration is so widely used, but i cant find any detail source on how it is being done.
anyone know where else can i get information on how to perform TRL calibration?
equation 4.74b:
equation 4.76b
