Hello all,
I have a 24V 0.4~0.5A solenoid that until now I have run from rectified (no smoothing) 24Vac, I am looking to create another version of the project running from 230Vac or 110Vac. Space is tight and will not fit a transformer or large components, and I also want to use the same solenoid.
Couple of ideas:
-Could I Triac/SCR the 230Vac so that the solenoid is getting 24Vac RMS?
-Should I use a 110Vac Solenoid and triac/scr that one for the 110 and 230 versions, using a separate solenoid for 24Vac version?
-What about a Planar transformer, coil on the top layer of PCB and separate coil on the bottom to drop the 110Vac to 24Vac, add more/less coils for 230Vac versions?
Any input would be appreciated!!
Thanks,
nodee
