A start for you:
Atmel Application Note: AVR323: Interfacing GSM modems
GSM LIBRARY for AVRs
ANd use google search engine
I hope that will help: https://www.olimex.com/dev/pic-gsm.html.
I think that before start writing code, it is most important to first connect your modem with a terminal software and drive it through there. You will see a lot of things that are not directly visible through code debugging. You will save a lot of development time in this way.parisash said:whould you please give me a source code
Start with the basics. Make and receive calls and sms, delete sms, calls listing and in general all basics that you already know from your mobile phone. Then you can write an MCU project faster.
When you will be needing more commands, you can first test them in the terminal software and then write the MCU code for them. I think this is the optimum way.
By the way, I believe that Windows Hyperterminal is an awful software. You can check out some more terminal software through this thread:
https://www.edaboard.com/threads/228501/
Hope that helped,
Alexandros
Yes, you connect GSM's Tx with interface's Rx and vice versa. You will need an RS232 driver for PC interfacing like MAX232, and a USB to serial cable bought from a local PC accessories store.parisash said:Do you mean that I download the terminal software and install
it on my computer? then try to connect it to my GSM modem?
