shaikss
Full Member level 4
I want to lower Vth of MOS in my design.
I am using 4-T cell rectifier using gate cross coupled architecture. I have attached the snapshot of the same.
This rectifier is for low power applications. So my input is in the range of 200mV.
For this reason, I want to lower the Vth of MOS device.
I tried to lower the Vth by biasing the gate voltage - That is, I have connected a external dc voltage source to the gates of MOSes.
With this, I am able to see some reasonable output. But I don't want to use external supply.
Somehow, I want to generate the biasing voltage within the rectifier without using external supply.
How is this possible? Please give me some hints to implement.
I have come across, some structure, second attachment. But couldn't get expected results. What may be the issue in the design?
Thanks in advance.
Thanks in advance.
