shipwreck
Newbie level 1
ac to dc conversion without transformer
I have disassembled a mains (240V 50Hz) outlet controller, it has a digital timer which controls a 48V relay to turn the AC socket power off and on. The digital controller and relay are powered by a low voltage DC circuit derived from the 240V AC mains power. A four-diode bridge rectifier converts the AC voltage to DC. The AC power to the bridge rectifier is connected as follows. From the AC neutral the circuit is a 1M ohm resister in parallel with a .33uF capacitor. From the AC active side the circuit is a 150 ohm resistor. I measure about 50V AC at the input diodes to the bridge and about 48V DC at the bridge outputs. I understand the bridge rectification and how the 48V DC is generated. My question is how is the 240V AC mains converted to 50V AC at the bridge rectifier?
